| Pin # |
Purpose |
Wire Colour(s) |
| 1 |
Ignition (+12V) |
Red/Black |
| 2 |
Lamda Sensor |
Black |
| 3 |
Petrol Pump Relay (red/yellow) and Alarm Module (black/blue) |
Red/Yellow |
| 4 |
Idle Speed Stabilizer |
White |
| 5 |
Magnetic Valve for Activated Charcol Cannister |
Green/Yellow |
| 6 |
Ground connections for the following:-
- Hall Sensor
- Engine Oil
- Temperature Sensor
- Air Temperature Sensor
- Throttle Potentiometer |
Brown/White |
| 7 |
Linked to pin 6 |
Brown |
| 8 |
Hall Sensor (+) |
Red/Black |
| 9 |
Air Temperature Sensor (+) |
Purple/Black |
| 10 |
Engine Oil Temperature Sensor (+) |
Brown/Red |
| 11 |
Yellow/Red |
| 12 |
Fuel Injectors Ground Connection |
Brown |
| 13 |
Diagnostics Connector T3/2
Ignition Transformer (terminal 31) |
Brown |
| 14 |
ECU Relay Positive Supply (via fuse 7) |
Black/Yellow |
| 15 |
(Not Connected) |
| 16 |
Ground |
Brown |
| 17 |
Throttle Potentiometer (signal) |
Blue |
| 18 |
Hall Sensor (signal) |
Green/White |
| 19 |
Ground |
Brown |
| 20 |
Diagnostics Connector K-Line T3/1 |
Brown/White or Grey |
| 21 |
(Not Connected) |
| 22 |
ECU Relay - Ignition Control |
Black/White |
| 23 |
Ignition Transformer (terminal 1) |
Black/White |
| 24 |
(Not Connected) |
| 25 |
(Not Connected) |
