Created 17.04.2007
F A Q
HydraulicTappets "clack-clack-clak" noise |
| Thema: Problem with my 1600i 16.08.2007 15:23:26 Von: sanji@seyres.net clac.mp4 (763357 Byte)
Hello Manfred I'm not sure if it's the same thing. furthermore, I've driven this car for 15000 km, and I've never heard it. Could you try to look at this video and tell me what you think about it.
Thanks a lot. 16.08.2007 Hello Jean-Daniel, i take a look and a ear ;-) at your video. I'm nearly shure, that the metalic clack...clack are the hydraulic tappets. It could be that this noise starts at once. Most times the oil level is to low. So take a look there. The oil level should be at maximum. Not in middle, not below. If you are lucky, its enough to fill in some oil. If this wouldn't help, try to use Liqui Moly.
regards 17.08.2007 10:46:15 Von: sanji@seyres.net Thank's a lot : it works !!! My oil level was a little bit low... Thank you. |
