wipers kaput.
Ignition cables (cross-references) ? :: Hydrostössel ausbauen
Autor Nachricht
gramey lad
Anmeldungsdatum: 27.02.2008
BeitragVerfasst am: 10 Aug 2008 9:12    Titel: wipers kaput. Antworten mit Zitat
What goes wrong with the wipers ? I seem to have lost my intermittent wipe and they wont park themselves.Is this a fault with the relay or do the switches on the column go wrong "and if so are there any alternatives to genuine parts Confused Any ideas much appreciated.
_________________
2003 mexibeetle (engine no ACD451023)
Nach oben
Anmeldungsdatum: 07.10.2007
BeitragVerfasst am: 10 Aug 2008 10:21    Titel: Antworten mit Zitat
That's not the relay, nor the switches, it's the wiper motor itself.
Inside the wiper motor are copper contacts so that it can park the wiper in the correct position. If these contacts are damaged, it stops in any position.
Open the plate of the motor, clean the contacts from old grease... usually it's the old grease that causes this symptom.
Martin
Nach oben
gramey lad
BeitragVerfasst am: 10 Aug 2008 12:31    Titel: Antworten mit Zitat
Thanks martin,i will try that.
_________________
Nach oben
Seite 1 von 1
(co) 2011 www.1600i.de
Hosted by 1600i.de
