Intake mainfold pressure sensor - no signal (sporadic)
Ölfilter und Hydrostößelklappern :: E series chip.
Autor Nachricht
phade
Anmeldungsdatum: 14.09.2007
Wohnort: Kent / Süd-Ost London - (Kent / South East London)
BeitragVerfasst am: 23 Jul 2008 21:51    Titel: Intake mainfold pressure sensor - no signal (sporadic) Antworten mit Zitat
Hi everyone,
My car had acted up on my way back from work tonight (it was revving up and down rapidly at idle) and decided to behave its self when I revved up the engine (to about 2,500 rpm) for about 10 seconds.
I quickly checked the fault code memory when I got back home tonight and found the following error:-
- Fault source: 00519 003
- Intake manifold pressure sender - G71
No signal /SP
The quick question I have is that is there anything else to look for before I remove the ECU from my car to check it's circuit board for dried solder joints, etc?
(I have already thought about unblocking the vacuum pipes and checking the rubber hose on the ECU, which I'll be looking at this coming Sunday).
Thank you everyone in advance.
Cheers,
Phil
Nach oben
phade
BeitragVerfasst am: 29 Jul 2008 21:42    Titel: Antworten mit Zitat
Hi everyone,
I have already found what the problems were, they were the following:-
- Partially blocked fuel pressure regulator rubber elbow (blew it out with compressed air)
- Some poor solder joints on the ECU's circuit board.
Thank you everyone for reading my post.
Cheers,
Phil
Nach oben
Seite 1 von 1
Ähnliche Beiträge
Keine neuen Beiträge map sensor fault? seb Technique - Technik 8 18 Jun 2008 17:09 Letzten Beitrag anzeigen
Keine neuen Beiträge Zilinderkopftemperatur Sensor Cris Technique - Technik 2 07 Nov 2008 18:12 Letzten Beitrag anzeigen
Keine neuen Beiträge Solved failure: Hall sensor was the b... Pegasín Technique - Technik 0 19 Jan 2009 20:46 Letzten Beitrag anzeigen
Keine neuen Beiträge fuel injection pressure xbacax Technique - Technik 3 10 Mai 2009 14:59 Letzten Beitrag anzeigen
Keine neuen Beiträge fuel pressure question xbacax Technique - Technik 3 15 Jul 2010 12:32 Letzten Beitrag anzeigen
(co) 2011 www.1600i.de
Hosted by 1600i.de
