		| Gearbox ! :: Auspuff ist undicht |
		| Autor | Nachricht |
		| nopap
 Anmeldungsdatum: 11.01.2008
				|  Verfasst am: 26 Apr 2008 17:30    Titel: Fuel Pump problem |   |
				| Hello, I'm the owner of a french buggy based on 1600i engine, registered on www.1600i.de car number 205
 if you are interested in having a look.
 I have a difficult problem with the engine since a while that i'm trying to solve,
 and maybe someone could help with some ideas:
 The fuel pump does not provide enough gas for some reason:
 when i switch on ignition, the pump is supposed to run about 1 minute, on mine it's 3 seconds...
 then when running i can hear the pump relay turning on and off so fast it's like a buzz sound.
 Relay is of course brand new...
 Of course the car does not run properly like that: the previous owner's mecanic did some hack and
 made the pump run permanently as soon as ignition is on. That's fine, the car runs great,
 but since a while with an idling problem that i suspect related
 to the pump giving too much pressure...
 This also means that the pump works fine !
 The Digifant has no error in vag-com.
 Does anybody has an idea why the pump would not run as expected ? I guess the ECU is providing on/off
 signal to the pump, of does it mean my ECU is in bad shape ?
 Thanks for any help ! And sorry for the english, i don't speak much german...
 Emmanuel.
 _________________
 N°205
		| Nach oben |  |
		| Red1600i
 Anmeldungsdatum: 07.10.2007
		| Nach oben |  |
 | Du kannst keine Beiträge in dieses Forum schreiben. Du kannst auf Beiträge in diesem Forum nicht antworten.
