But you will have a problem with the cylinder head temperature sensor... either you weld or cut a nut on the head or you use the sensor as a 5.th push rod tube on cyl 3 with a wire extension
Verfasst am: 26 März 2008 17:26 Titel:
Hiya xbacx,
The engine oil temperature sender is located on the rear left hand side of the engine bay, next to the number 4 cylinder part of the cylinder head. It looks like an overgrown bolt with a white 2 pin plug attached to it.
