Verfasst am: 29 Feb 2008 12:10 Titel: 1600i problem with acceleration
Hello,
My name is Przemek, I'm from Poland, Warsaw. I bought VW Kafer Mexico 1997.
Car condition is very good I have only one problem. When engine is hot (for example 30 min of driving in city) and when I try to add speed, car is accelerating but with twich, nervous. This happen only when engine is after work, hot.
Verfasst am: 29 Feb 2008 15:03 Titel:
it seems that any of the following could be causing your beetle's engine not to run properly:-
- hall sender intermittant
- ignition module
- engine oil temperature sender (NTC2)
- air intake temperture sender
you will nee to use a diagnostics kit to find out what's wrong with it, however you can also find out by checking the condition of those connectorsm as well.
