Themen
Antworten
Autor
Aufrufe
Letzter Beitrag
Stoßstangen-Klebestreifen
3
Kaefer1954
402
13 Okt 2008 18:24Doc
Finally... videos of my engine failing (not detected yet)
10
Pegasín
483
11 Okt 2008 19:23Pegasín
Ignition transformer 6N0 905 104
11
Pegasín
359
08 Okt 2008 8:28phade
Hauptstadtkäfer in Not. (Danke, geht wieder!)...
5
hide beetle
548
02 Okt 2008 16:09hide beetle
1600iKitOBDII
0
Dr.Phunk
426
26 Sep 2008 10:07Dr.Phunk
Aktuelle Infos zum HJS-Sammelrohr
7
ruebiracer
667
25 Sep 2008 18:41Doc
Druckregler von alt auf neue Ausführung ?
2
Bug 1600i
394
25 Sep 2008 17:33Doc
Daten zu den serien Einspritzventilen???
0
BlackBug
193
24 Sep 2008 23:38BlackBug
silly, performance question :)
0
xbacax
306
23 Sep 2008 15:32xbacax
HJS Kat
11
RRKäfer
819
22 Sep 2008 6:07ruebiracer
Where is the fuel regulator?
1
Pegasín
274
17 Sep 2008 20:15Doc
harder valves springs
2
xbacax
223
15 Sep 2008 22:58xbacax
Zündzeitpunkt E85-Chip
4
AK 47
526
11 Sep 2008 15:09Leini
REV counter.
1
gramey lad
377
08 Sep 2008 12:56Doc
Hilfe!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
10
Bug 1600i
1241
05 Sep 2008 21:15Doc
Failure in engine... maybe fuel pump?
6
Pegasín
515
01 Sep 2008 21:07Pegasín
Motorprobleme 1600i
3
Wirthi
686
31 Aug 2008 11:36phade
Pfeifen
0
h.sch
280
29 Aug 2008 16:50h.sch
questions about lifters
0
xbacax
252
27 Aug 2008 11:26xbacax
Widerstand Einspritzventile
8
hilli
674
26 Aug 2008 21:12RDplus
Problems with my Beetle 99
0
nachitoys
334
25 Aug 2008 7:50nachitoys
Spurverbreiterungsrad, chrom, 5,5 x 15 ET25
2
hide beetle
457
22 Aug 2008 17:32Red1600i
What are necessary to have a complete diagnosis kit ?
5
Pegasín
473
19 Aug 2008 18:49phade
Kaltlaufregler für Euro2
2
Ralf
624
16 Aug 2008 16:50Guido
Abgasanlage
2
Ralf
416
14 Aug 2008 20:59hide beetle
Alcohol E85 (Biofuel) in ACD engine???
3
Pegasín
603
13 Aug 2008 18:01RDplus
Hydrostössel ausbauen
0
AK 47
383
12 Aug 2008 13:16AK 47
wipers kaput.
2
gramey lad
210
10 Aug 2008 12:31gramey lad
Ignition cables (cross-references) ?
3
Pegasín
311
10 Aug 2008 11:59Doc
Gaskabel gerissen!!
5
Tortugamexicana
331
07 Aug 2008 11:52Tortugamexicana
Chrom-Fensterzierrahmen bis Modell 1995
1
captainfuture
473
04 Aug 2008 21:19captainfuture
Durchnittsverbrauch
7
Gurkn
756
04 Aug 2008 18:44sTs28
E series chip.
4
gramey lad
792
02 Aug 2008 8:15gramey lad
Intake mainfold pressure sensor - no signal (sporadic)
1
phade
363
29 Jul 2008 21:42phade
Ölfilter und Hydrostößelklappern
0
Erol
561
27 Jul 2008 12:35Erol
Reifen vorne kommen an die Federlenker !
4
Bug 1600i
433
24 Jul 2008 20:30Bug 1600i
Hupe geht plötzlich nicht mehr
8
Erol
526
24 Jul 2008 19:08Hansebug
Source for ignition leads in the uk
4
seb
268
23 Jul 2008 9:48phade
Verteilerkappe defekt oder Zündkabel oder???
2
plasma
361
23 Jul 2008 6:38plasma
Which lambda probe would suit my mexican beetle ?
1
phade
321
22 Jul 2008 17:56Red1600i
Welche Lambdasonde passt der 2000er Mexiko-Kaefer ?
0
phade
386
21 Jul 2008 20:38phade
Vorteile eines länger übersetzten Getriebes
[ Gehe zu Seite: 1 , 2 ]
25
stratiii
1567
21 Jul 2008 12:08Doc
map sensor fault?
8
seb
682
14 Jul 2008 20:43Timo
Unterschied HJS Kat fur 1200er/1600er Motor?
3
Timo
489
12 Jul 2008 17:03Red1600i
Lambda probe.
3
gramey lad
406
06 Jul 2008 16:21phade
Käfer 1600i springt kalt schlecht an, nimmt kein Gas an
4
Raana
696
04 Jul 2008 18:35Red1600i
Motor läuft ab und zu Unrund
1
Sven
510
03 Jul 2008 10:19draircooled
Zusatzinstrumente einbauen, aber wie
10
plasma
834
01 Jul 2008 16:14Dr.Phunk
Verschiedene 1600i Fragen
13
Herrkäfer
1229
29 Jun 2008 14:28Douglas Hanauer
Fragen zu Zünd- und Türschloss
3
icke WES
377
29 Jun 2008 9:05icke WES
Ölmenge
6
RRKäfer
621
29 Jun 2008 6:15siegfried41
OIL FILLER
3
Gary
498
18 Jun 2008 7:16phade
Chiptuning – welcher Anbieter?
5
Erol
1035
17 Jun 2008 10:03blackmexschrauber
Ölkühlerthermostat
3
Herrkäfer
321
16 Jun 2008 1:14Herrkäfer
Ausgleichsbehälter zerbrochen, was nun?
9
jens-berlin
574
15 Jun 2008 23:24icke WES
Getriebeöl wechseln - nach wieviel Kilometern?
5
Erol
759
14 Jun 2008 19:17Erol
Help!
6
Elch
687
12 Jun 2008 13:39Elch
Käferwerkstatt in München (südl.) bzw. Starnberg u. Umgebung
2
Schmusemaus81
248
09 Jun 2008 16:45Erol
sportlenkrad mit narbe und tüv
1
green_MadMex
344
09 Jun 2008 15:51green_MadMex
Talbot Spiegel
3
hide beetle
374
08 Jun 2008 12:27Chibo
Kleinere Riemenscheibe am 1600i
3
Leini
598
05 Jun 2008 18:50green_MadMex
hydroklappern in berlin
20
green_MadMex
1147
05 Jun 2008 18:16green_MadMex
endrohrblende - wer hat eine und woher ist sie?
2
green_MadMex
406
05 Jun 2008 9:51green_MadMex
Kipphebel andern
0
Käferfahrer
321
03 Jun 2008 21:01Käferfahrer
Nochmal Autogas
6
siegfried41
531
01 Jun 2008 1:05icke WES
Leerlaufdrehzahl sehr zu hoch
4
Erol
435
27 Mai 2008 19:18Erol
Oil filter location.
3
gramey lad
424
26 Mai 2008 18:53Pegasín
Hilfe Motor springt nicht an!!
3
mexico006
741
24 Mai 2008 23:18mexico006
Overfuelling - 1996 Kafer / Beetle 1600i Mexican
10
MexiBugUK
5118
24 Mai 2008 13:19phade
Schalter für Rückwärtsgang
2
Dr.Phunk
300
24 Mai 2008 11:26Dr.Phunk
1600i Kaltstart mit kleiner blauer Wolke
4
Bort
549
23 Mai 2008 10:42Bort
Probleme mit der Grundeinstellung
3
hilli
492
22 Mai 2008 22:42Doc
Lampdasonde
4
TexMex
324
22 Mai 2008 21:34TexMex
Throttle / accelerator cable lenghth
1
thedishking
215
22 Mai 2008 16:17Doc
Cross reference for clutch
1
Pegasín
245
20 Mai 2008 23:51phade
Einzeldrosselklappensteuerung
3
RRKäfer
429
19 Mai 2008 9:17Red1600i
ASU und CO -Wert
3
ACD51143
461
17 Mai 2008 22:26cdsepp
New member, need help with timing
3
thedishking
412
15 Mai 2008 23:18thedishking
Passen Auspuffteile vom normalen Käfer??
2
stratiii
516
13 Mai 2008 20:50Doc
Bedienungshinweise Transponder und Kopfstützen beim 2003er S
2
Hans
378
12 Mai 2008 19:10tma
Thermostat
4
stratiii
442
11 Mai 2008 10:51stratiii
Nachwuchs im Käfer(Maxi-Cosi)
2
S.Gonzales
429
05 Mai 2008 20:48Chibo
Öleinfüllstutzen (Kunststoff) gegen Alu-Ausführung tauschen
4
ACD51143
475
04 Mai 2008 8:02Bobby-911
Zigarettenanzünder nachrüsten, aber wo???
4
Marc
437
03 Mai 2008 18:15Douglas Hanauer
Bremslichtschalter wie die Stecker ?
2
Sven
361
01 Mai 2008 20:24Sven
div. Ersatzteile um den Motor
1
RRKäfer
478
01 Mai 2008 11:10Robert
Quietschende Bremsscheibe(n)
2
OdenwaldTriker
651
30 Apr 2008 5:35OdenwaldTriker
Jetzt brauche ich Hilfe mit der Elektrik
5
Gurkn
687
29 Apr 2008 21:51Timo
Elektrisches Faltdach Käfer "Open Air"
3
Rafael
1300
29 Apr 2008 20:51Chibo
dauerläufer???
0
edgarwallace
312
29 Apr 2008 20:18edgarwallace
Kurbelwelle Schwungrad Drosselklappen Nockenwelle Kipphebel
8
Chibo
777
28 Apr 2008 20:08Red1600i
1600i springt nicht an
9
dome
759
27 Apr 2008 17:56Red1600i
Auspuff ist undicht
3
stratiii
486
26 Apr 2008 22:27Timo
Fuel Pump problem
1
nopap
365
26 Apr 2008 17:46Red1600i
Gearbox !
4
Ian
546
25 Apr 2008 9:18phade
ACD-Motor dringend gesucht...
2
Douglas Hanauer
466
25 Apr 2008 7:20Walter
Schalter für Alarmanlage Kofferraum
2
ruebiracer
444
22 Apr 2008 6:26ruebiracer
Verkaufe meinen 1600i Motor
3
Walter
780
20 Apr 2008 10:05TexMex
Drehzahlbegrenzer Serie und SKN Chip
13
Chibo
697
20 Apr 2008 7:43Chibo
Alkohol???
2
icke WES
479
19 Apr 2008 17:47icke WES
Siehe Beiträge der letzten: Alle Themen anzeigen 1 Tag 7 Tage 2 Wochen 1 Monat 3 Monate 6 Monate 1 Jahr
